TTE prep continues: New clutch installed! <wuss-boy farmed this one out>
Old Jun 3, 2008 | 06:00 PM
SpongeBobTT's Avatar
Default TTE prep continues: New clutch installed! <wuss-boy farmed this one out>
Well, I guess my issues date back about 18 months.
Problem came and went... somedays it wouldn't skip a beat, some days I was slipping 4-500 RPM. Started in 6th under heavy load, then 5th and finally 4th. Of course since I ordered the clutch it has been fine. No matter how hard I tried the mf-er would not slip.
Anyway... finally got tired of it enough to replace it. Went with South Bend Stage II (TF series) and after much contemplating, a new, stock dual mass flywheel. (pic not exact as this is the SMF part)
<img src="http://pictureposter.audiworld.com/99420/dscf14461.jpg">
I had the shop save the parts (cuz I'm a dork and like to see how stuff works) and although they said it looked "OK", it seems to have heavier wear on the outer edge and appears sommewhat convex on that side. After 50 mile "easy" ride home I'm very happy with the feel - exactly like the stocker. Hopefully no slippy when I get on it.
Also had them replace a torn CV boot and align it. All that's left is brakes and we're ready for TTE - yay!
Old Jun 3, 2008 | 06:06 PM
Horch it's Avatar
curious, are you chipped?
Old Jun 3, 2008 | 06:18 PM
Default Guess I should add a mod list....
Revo 93, VTDA, Boost Machine, Forge 007, Borla exhaust, Koni Coilovers and... of course, the Pimp-Daddy bling rims.
AchTTung--Vollgas's Avatar
See you there!
Old Jun 3, 2008 | 07:09 PM
Horch it's Avatar
Default I'll be needing a clutch kit soon
I got the revo too and was contemplating a stg II kit...something close to OEM in feel but with more able to handle more torque. And I don't want the noise associated with lighter flywheels....so dual mass may be in order too....I think your kit is good for 375 lbs. of torque?
Old Jun 3, 2008 | 07:28 PM
TTwizted13StrtRcr's Avatar
Member
Default what type of wheels are those?
size and weight too?
Old Jun 3, 2008 | 10:42 PM
HACK THS's Avatar
Default What did the shop charge to install a new clutch and flywheel?
Wondering if they quote before they start, or just gave you a bill for the hours it took them at a set rate?
Old Jun 4, 2008 | 03:46 AM
TTinCT's Avatar
Rest In Peace
Default new clutch slave too?? >>>>>
wonder if the slave was leaking on the clutch plate...either way it needed to be done....
Go easy on the break in for the first 500 miles or so.....
Now you will have NO excuse for losing the Autocross! ;-)
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 4, 2008 | 04:18 AM
PracTTical's Avatar
how much was labour on that? considering this job by the end of summer...
Old Jun 4, 2008 | 04:58 AM
AxeYrCat's Avatar
Member
Look like Axis Supermesh 19s. I don't know the weight, though.
2low4snow
May 7, 2006 09:21 AM
Jay^Jay
Dec 20, 2003 04:27 PM
AUDIOZ A4
Performance and Tuning
May 12, 2003 06:33 AM
Shoe
Oct 17, 2002 10:48 AM
the Lad
Oct 7, 2002 08:45 AM
