Boost Gauge Install Questions
Old Jun 6, 2008 | 05:14 AM
mastrpdawg's Avatar
Default Boost Gauge Install Questions
Hi All,
Just ordered my vent ring from modshack and a prosport gauge. Before the stuff gets here, I had some questions.
#1 Where is the best place to tap in the engine compartment to attach the hose from the gauge? I've seen the FPR, DV, or the vac line coming from the manifold. Which is best?
#2 Where should I connect the white "live" wire from the gauge to a power source? I've seen it connected to the x75 terminal and spliced onto the light blue headlight switch wire. Which is the SAFEST (no fires please)? Also I've seen it recommended that an inline fuse be used on the white wire. Is this necessary? If so, what amp should I use? 10 or 5?
Thanks in advance!!!
04 225QCM
Old Jun 6, 2008 | 05:44 AM
blackfnTTruck's Avatar
Default Answers here...........
Tap into the FPR and use the blue wire on the back of the headlight switch for variable voltage for the backlight.<ul><li><a href="http://public.fotki.com/blackfnTTruck/defi_boost_gauge_install/">http://public.fotki.com/blackfnTTruck/defi_boost_gauge_install/</a</li></ul>
Old Jun 6, 2008 | 05:49 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
2nd
Old Jun 6, 2008 | 06:39 AM
mastrpdawg's Avatar
Default Re: Answers here...........
Thanks blackfnTTruck!
Do you think I need an inline fuse for the connection to the blue headlight wire?
Or is that only needed if I connect to the x75 terminal?
Old Jun 6, 2008 | 07:04 AM
Tech Guru
Default It will not hurt to use one, and it can be rated very low. A 5 amp would be fine, and a I bet a
1-amp would work as well.
Old Jun 6, 2008 | 09:06 AM
Default As Mike said it probably wouldn't hurt, probably better to place a fuse at....
<center><img src="http://images36.fotki.com/v1202/photos/6/645139/6006389/gaugepodwiring006-vi.jpg"></center><p>
the blue wire connection, that way if the wire rubs on the frame somewhere, you'll be safe. I know the specs on the Defi gauges, pull about 240ma fully powered. The 75x terminal is +12 volts with ignition on, if you use that one, you should definitely use a fuse, at the connection site. I used that for power on the Defi gauges and used a 1 amp fuse.
Old Jun 6, 2008 | 11:21 AM
mastrpdawg's Avatar
Default Thanks for the info blackfnTTruck and Mike!!!
I've got the euro mirrors and APR chip..soon will have the boost gauge.
Can't wait to see the gauge in action. I'm particulary curious because I sense that immediately after start up the boost is strong on acceleration from a dead stop but after a few mins of driving, it seems like I don't have any boost taking off from stop signs. Hopefully I can see what's going on with the gauge!
EBG 18T [Eric]
New England Discussion
Jan 16, 2008 03:12 PM
TTuned
Oct 4, 2004 05:06 PM
TTuned
13
Oct 1, 2004 01:51 PM
Horch it
Mar 3, 2004 11:30 AM
carlosii
11
Feb 24, 2003 06:09 PM
