Airbag Module
Old Jun 6, 2008 | 06:59 AM
Blamsters's Avatar
New Member
Default Airbag Module
I've got the dreaded 65535 fault code coming out of my airbag module. I've been told by some that this means it's absolutely dead! I've been told by others that it can be repaired quite easily...any thoughts?
Also, I've got my driver's side underdash all open...don't see it there...and I have the center consule half undone and no joy there either....HELP!
Old Jun 6, 2008 | 07:19 AM
alms_TT_ny's Avatar
Default Isn't it located ahead of the smugglers box?
can't you just pop off the two triangles then remove the interior trim to access it?
Old Jun 6, 2008 | 08:15 AM
Blamsters's Avatar
New Member
Default Re: Isn't it located ahead of the smugglers box?
When you say the "triangles" do you mean the brushed crome "leg guards" on either side of the center console?
Or do you mean the black plastic side pieces to the right of the gas pedal?
Old Jun 6, 2008 | 09:31 AM
Blamsters's Avatar
New Member
I found it. I didn't need to take down the lower instrument panel (Doah!) as prescribed by some. It is on the floor at the most forward position on the center "hump". You only need to take off the passenger side "triangle" to get to the black plastic forward side cover (two screws) and just the 2 screws on the driver side forward covers. It has three nuts holding it in place, two at the back end and one at the passenger side front end.
50cool50
Audi A3 / S3 / RS 3
Feb 2, 2016 02:00 PM
xxA4Santorinxx
Jan 15, 2008 02:20 PM
Avants
Jul 11, 2005 03:51 AM
Lurk'n
9
Sep 30, 2004 08:07 PM
maru
Jun 9, 2003 11:07 AM
