Put ECS 10mm spacers on.... a spacer fitment question
Old Jun 6, 2008 | 02:54 PM
BluHeaven's Avatar
Default Put ECS 10mm spacers on.... a spacer fitment question
they weren't 100% absolutely perfectly flat... sitting them on a flat surface I could get them to wobble just a small amount.
Anyways... laying the wheel flat and putting them in there might have been a 1 to 2 tenths of a mm in some spots between the spacer and the wheel. I could slip a piece of paper between them. If I pushed on the spacer a bit with my hand these micro spaces went away.
I put them on and torqued them very slowly in the air, starting with finger tight then hand tight and incrementing up 30 ftlb, 55, 70, then 90. Somewhere after finger tight and between hand tight and 30ftlb all micro gaps went away and they were flush all around.
Am I ok? I ask because ECS states that some hubcentric rings on aftermarket wheels prevent the 10mm spacers from sitting flush to the wheels surface. They show this picture.
<img src="http://www.ecstuning.com/stage/images/dis/1414/600/1414.jpg">
I'm assuming they are talking about the massive gap shown though.
I emailed ecs about it as well.. but thought I'd ask the collective as well in case anyone else had the ECS 10mm.
Old Jun 6, 2008 | 02:56 PM
GorTT's Avatar
Default Have you driven it at speed? Any vibration?
probably ok, but doesn't sound ideal.
Old Jun 6, 2008 | 02:58 PM
GoKart3's Avatar
H&amp;R FTW.
Old Jun 6, 2008 | 02:59 PM
BluHeaven's Avatar
nope... not till I hear back from ECS
Old Jun 6, 2008 | 03:00 PM
BluHeaven's Avatar
meh... H&amp;R makes oem wheel fitment only
GeTT da NeTT's Avatar
Hi Dani. Based on your description of your installation, you should be fine. Should look good too!
AxeYrCat's Avatar
Member
Default Return them and get some quality parts. =(
I have had nothing but BAD luck with ECS parts.
I'd return them and run away. Quickly.
Old Jun 6, 2008 | 03:01 PM
AxeYrCat's Avatar
Member
5 minutes with a Dremel and your centering rings, and they fit just fine. ;-)
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 6, 2008 | 03:02 PM
AxeYrCat's Avatar
Member
Don't hold your breath: It's after business hours on Friday.
Old Jun 6, 2008 | 03:03 PM
BluHeaven's Avatar
lol... have you done this before?
