Grille replacement
I did see a couple of posts from a those who ripped out the front grille using what appeared to be either a kind of saw (forgot the name) or a dremel.
For those of you who have swapped your grille by cutting out the old one, anyone have a more detailed account of exactly how you went about it? Did you start from the center and just cut outwards and start removing piece by piece?
Before anyone comments about how easy it is to remove the front bumper, I don't have a driveway or jackstands, and would much prefer to lose the $50 or so to cut out the old grille then go through the trouble of removing the old bumper as long as I knew it was safe to do so.
I'd rather go through the trouble of carefully cutting out the old grille and throwing it away, then buying jackstands, lifting the car, trying to remove the front wheels, taking off the front bumper, and probably breaking parts of grille in the end, just to do everything again in reverse then just cutting out the old grille.
