time to upgrade brakes... couple questions >>
i know i wanna do hawk pads (or something of equivalent performance)
rotors... i wanna do cross drilled and slotted (or one or the other)
so where can i order pads, and performance rotors but keep the factory size?
also... the pistons on the TT >> are they the 'screw in' pistons, or 'push in' pistons?
thanks guys
As for rotors - i'd do slotted instead of drilled/slotted. Any good quality rotor will work.
Piston on the front caliper is push in and screw in on the rears.
I'd also upgrade the fluid to Motul 600 and honestly - go to stainless lines in the front. That will make a big difference in pedal feel.
The front calipers push in and are easy. The Carbotech pads don't have wear indicators so I just cut off the old ones and soldered the wires together so the light wouldn't go on in the dash.
The rear calipers are a pain - they turn in. Get the tool from Autozone (pay a deposit and return for full refund). Spend a few dollars and get an impact hammer and new screws for the rotors. You'll be glad you did.
Since I'm **** about the car I even got all the carrier bolts replaced from ECS.
Had Ferodo pads before and they work great but the brake dust was a killer. I can't tell the difference in performance from the Carbotech pads.
<a href="http://www.zeckhausen.com/">zeckhausen racing</a>
hps's were dusty and noisy, now The ceramics work real well and are not dusty or noisy, and seem to work real well with the brembo replacement rotors.
oh and i drive about 700 miles a week and do not baby it
I got all of it from tire rack
Look at this site. It has good pad info.
Different people have different needs. You will need to make your pad decision based on your driving characteristics. One note. I tried the Hawk Performance Ceramics and was not pleased. Not enough bite. Required high pedal effort.<ul><li><a href="http://www.purems.com/products/page.php?pageKey=10">http://www.purems.com/products/page.php?pageKey=10</a</li></ul>
