rear suspension knocking question (with pic to entice curiosity)
Old Jul 13, 2008 | 09:22 AM
jhoeppel's Avatar
Default rear suspension knocking question (with pic to entice curiosity)
<center><img src="http://pictureposter.audiworld.com/65932/rearsuspension.jpg"></center><p>
I've had a relatively quiet rear clunking or knocking that's most noticeable at slow speed whenever the chassis shifts. You can recreate it by rocking the rear up/down when the car is stationary. It appears to come from the <b>where the rear sway bar connects to a link of some kind</b> (highlighted in yellow on the pic). If you rock the end of the sway bar back and forth by hand when the car is stopped, you can hear/feel a bit of a clunk or knock.
An indie alignment guy said there shouldn't be any play here and suggested I'd prob'ly have to simply replace the link (the nuts are torqued to spec). Has anybody (1) done this before; (2) know what the official name is for this "sway bar link," and (3) do you figure the stealer is my best source?
Thanx, ~john
<i>BTW, it's a Neuspeed 19mm rear bar on a quattro coupe</i>
Old Jul 13, 2008 | 09:28 AM
TTinCT's Avatar
Rest In Peace
Default that will go bad.....i replaced all 4 on my car at 100k or so>>>
when the knocking started...easy job and yes they need to be VERY TIGHT...there should be no slop there...
Drop links can be gotten from PureMS or ECS.....
Old Jul 13, 2008 | 10:10 AM
MikekiM@PureMS's Avatar
Former Vendor
Default Easy to replace.
They are indeed simply called sway bar links.
Dealerships are great if you're in a bind and need something right away, but rarely are they the best.<ul><li><a href="http://www.purems.com/products/product.php/II=1456">Rear Sway Links</a></li></ul>
Old Jul 13, 2008 | 11:19 AM
jhoeppel's Avatar
Default Thanks... just ordered 'em.
need to relube the sway bar bushings anyway. Might as well get dirty once.
~john
Old Jul 13, 2008 | 01:47 PM
RoberTT-WWCD's Avatar
Default Pics and instructions here...>>
<ul><li><a href="http://public.fotki.com/RoberTT/maintenance/sway-bar-down-link-/">Down links...</a></li></ul>
SpeedyDTP247 CQ+UrS4
Apr 15, 2006 03:54 PM
CrazyCab
Nov 8, 2004 06:17 PM
Ghostfire
26
Oct 8, 2004 07:09 AM
Phil
Mar 20, 2004 03:13 AM
santorin288
Oct 3, 2003 12:09 PM
