my car went into limp mode tonight on the way to my friend's house
i never knew such relatively simple problems could cause so much sadness..
i want my baby back..
still no check engine light, still wont start after hot stop, still showing 121 on the HVAC (almost continuously now)... fans on at highway speeds (not supposed to happen)...
i hope they can narrow down the issue tomorrow. if they can't i'm calling the dealer. fark.
Good luck. Stop driving that thing till you fix it.
on the ride to work this morning my mechanic was 'startled' by the behavior exhibited by the climate control block 49 readouts, he said it wasn't possible for the car to jump around like it was.
1. clean you coolant tank level sensor
****be carful not to burn your self*****
2. locate the return hose from your heater core in the engine bay near the fire wall,run the engine up to temp,
if its cold, your heater core is blocked,
3. check you radiator inlet and outlet lines for a huge diference in temp/ feelable pressure by hand, if there is a huge disparity between the pressure and return, radiator has an issue.
4.after run coolant pump https://forums.audiworld.com/tt/msgs/1521900.phtml
5.using vag com, go to engine, *with engine off*
select output tests, and go through them all, the after run coolant pump should get activated.
6. next, go to instruments in vag com, again select output test, this will let you know if your cluster is ok or not for calibration, exp. all the needles will move together.
7. hvac, output test.
mabee this will help, or not.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1521900.phtml">https://forums.audiworld.com/tt/msgs/1521900.phtml</a</li></ul>
