looking at replacing my battery... any kits for lightweight batterys and boxes for the TT?
Old Jul 14, 2008 | 06:17 AM
ZGTT's Avatar
Default looking at replacing my battery... any kits for lightweight batterys and boxes for the TT?
TIA!
PracTTical's Avatar
Default look up braille batteries on teh searches.
teeny weeny and lightweight
Old Jul 14, 2008 | 06:27 AM
TTinCT's Avatar
Rest In Peace
Default also one that will require you to plug the car into a trickle>>
charge if you leave it more than a week on its own....
Old Jul 14, 2008 | 06:30 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Rob your lawn tractor.....:-)
or $29.99 at Lowes...
Old Jul 14, 2008 | 06:48 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
The concept of "No Free Lunch" is still a difficult one for some..:-)
Old Jul 14, 2008 | 06:51 AM
ZGTT's Avatar
Default I saw that when I did a quick search steve.. Living in a warm climate the cranking needs
are some what less I would imagine. Since this is my daily driver and is driven nearly every day.. trickle charging is not required.
may just get a OEM esque one.. just thought I would look at the options for size and looks.
Old Jul 14, 2008 | 06:53 AM
TTinCT's Avatar
Rest In Peace
Default well....most go after the weight >>>
"savings" as an advantage to me is not worth it, unless you are converting to a true track car. 18lbs is a lot, but the reliability to me is more important....and relocating to the rear is sorta lost with all the cable that needs to be run....probably the same weight and you are actually dispersing the savings across the whole chassis.....
yeah...i am rambling....
closing in on 400 hits on the "other" forum...;-)
ZGTT's Avatar
Default what lawn tractor?
<center><img src="http://pictureposter.allbrand.nu/pictures/zgtt/delray+beach+home/newshutterspic.jpg"></center><p>I have "people" that do my acre of grass. ;-P
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 14, 2008 | 06:54 AM
TTinCT's Avatar
Rest In Peace
Default Interstate is what i would recommend Bob>>>
a bit lighter than OEM......and a solid battery....IMO
Old Jul 14, 2008 | 06:55 AM
ZGTT's Avatar
Default thanks Hans.
saw you were happy with your box. What model number fit?
