1st to 2nd shift
Old Jul 14, 2008 | 11:53 AM
Warhawk's Avatar
Default 1st to 2nd shift
Shifting from first to second isnt as smooth as it should be, there is no grinding at all, it just doesnt seem to glide from first to second as the other gears do on the shifter. IE: when im going from 1 to 2, it doesnt slide in as well on the actual shifter and the actual shifts arent very smooth. Any ideas? Hopefully not a syncro issue.
Old Jul 14, 2008 | 11:56 AM
PracTTical's Avatar
have you changed your tranny fluid to redline? has solved many problems here before..
Old Jul 14, 2008 | 12:11 PM
JohnLZ7W's Avatar
Could also try realigning the shift mechanism
Old Jul 14, 2008 | 12:21 PM
Warhawk's Avatar
Default Is there a guide?
Im a mechanical noob, was wondering if there was any how to articles on how to change transmission fluid on a 02 180Q
Old Jul 14, 2008 | 12:26 PM
PracTTical's Avatar
Default should be the same as this...
enjoy!<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/maintenance_items/transmission_oil/">Transmission Oil Change</a></li></ul>
Old Jul 14, 2008 | 06:33 PM
jhoeppel's Avatar
Default new fluid could help, but adjusting the shift mechanism is important, as JohnLZ7W sez... >>
in my own case, neither a change to new juice (two different versions of Amsoil) nor a linkage adjustment did the trick. I'm convinced my 1-2 syncho is wonky. Slow and careful shifts are required for me. And this is a known, and oft complained-about issue on TTs and other A4-platform VW cars (NBs, Golfs and Jettas).
But you might get lucky--adjust the linkage and change out the fluid to Amsoil or Redline. As 01TT225 sez, the oil change procedure is in the FAQ. You might need a Bentley for the linkage adjustment procedure, although it only takes 5-10 mins. If you don't have a Bentley, check DieselGeek's webpage; I think he has a good procedure, with pics, which can be adapted for the OEM linkage adjustment.
~john
ChronoGN
Dec 2, 2008 09:41 AM
snowchaser
Feb 18, 2006 02:58 PM
EGainer
Jun 2, 2004 12:11 PM
Max'sCoupeGT
Dec 1, 2003 07:33 PM
ND4SPEED
Jan 14, 2002 01:18 PM
