Timing Belt Replacement
Old Jul 15, 2008 | 03:39 PM
TCretella's Avatar
Default Timing Belt Replacement
I have a 2005 TT roadster that is approaching 57K miles. So I'll be replacing the timing belt soon and after searching the forum I know that I should replace the TB, Tensioner, Water Pump and the pulley. Am I missing anything else I'm in Southern NJ and I need to start calling around to get pricing and I'm sure each place will give me a different answer to what will need to be replaced. Cherry Hill Audi quoted me over $2000 to do a full service TB replacement. I haven't bothered to ask them what it includes since I went into sticker shock when I heard $2000. Any suggestions to what else should be replaced? Thanks!
Old Jul 15, 2008 | 03:41 PM
Blue TTop's Avatar
Consider adding a thermostat since you are in that deep.
Old Jul 15, 2008 | 03:45 PM
JohnLZ7W's Avatar
$2000 is very high for a TB change, check with local indy shops
Old Jul 15, 2008 | 03:47 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Check with Awe Tuning......>>
They're not far up the road in Willow Grove PA...Good reputation..<ul><li><a href="http://www.awe-tuning.com/index.cfm">http://www.awe-tuning.com/index.cfm</a</li></ul>
Old Jul 15, 2008 | 03:50 PM
scoTT la rock's Avatar
Default KMD=750 out the door....
mountainside NJ
kmdtuning.com
i take my car there for everything. awesome job!!
Old Jul 15, 2008 | 04:13 PM
Hank's Avatar
Default I had mine replaced for about $1300, but that was several years ago when the ...
dollar was worth something.
Old Jul 15, 2008 | 05:55 PM
heinzboy57's Avatar
Default $750 including all parts?
wasn't sure if that's what you meant by 'out the door'..or if you brought in your own 'kit'
jhoeppel's Avatar
Default Had mine done at an indy shop for $875 w/ metal impeller h2o pump
$2k =way too much. And from a dealer you'll get the same crappy plastic impeller pump.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 15, 2008 | 06:07 PM
ErnesTT's Avatar
Default Re: Check with Awe Tuning......>>
AWE Tuning doesn't installing timing belts.
I went to Holberts Audi in Doylestown PA last fall. I had everything done for $950
Old Jul 15, 2008 | 08:58 PM
ArTT Vandelay's Avatar
Default get the dieselgeek kit for $259 and the shop should not charge more than $6-800
if they do you are getting handled.
