EPC light? First start-up / Drive. BT Set-up
Old Jul 15, 2008 | 04:23 PM
bullitz400's Avatar
New Member
Default EPC light? First start-up / Drive. BT Set-up
Hey guys. Finally started my car. Runs real good until i start getting on the throttle. I have an EPC light that comes on. Not sure if it is limp mode or not. I restart the car and it shuts off? The n75 valve is plugged in but currently not hooked up to anything. Could this be the source? Thanks
Old Jul 15, 2008 | 06:07 PM
bullitz400's Avatar
New Member
Default Re: EPC light? First start-up / Drive. BT Set-up
Now only makes 8-9 PSI but the EPC light doesnt come on?
Old Jul 16, 2008 | 03:04 AM
Scenic Driver's Avatar
Default First step ..
Get a vag-com and scan the car for dtc's
Old Jul 16, 2008 | 04:31 AM
Lowcountry's Avatar
What BT setup are you running?
Old Jul 16, 2008 | 05:48 AM
TonyStarkz's Avatar
exactly what i told him on vortex. Gotta scan to see what the issues are.
Old Jul 16, 2008 | 08:53 AM
bullitz400's Avatar
New Member
Default Re: exactly what i told him on vortex. Gotta scan to see what the issues are.
Pagparts Gt2871R, 630cc Tapp File. Where and what model vag-com should I get? Does it have anything to do with the N75 not being hooked up to anything? I am also getting a coolant sensor light. Not the low coolant but coolant sensor pops on.
Old Jul 16, 2008 | 09:24 AM
TonyStarkz's Avatar
there is only one coolant light so I'm unsure what you mean. So long as the N75 is plugged in.
Old Jul 16, 2008 | 01:41 PM
bullitz400's Avatar
New Member
Default Re: there is only one coolant light so I'm unsure what you mean. So long as the N75 is plugged in.
It appears on top of where the main screen is. IT has the coolant sign and then says sensor after it. N75 is plugged in. Put it up to about 18 psi and runs good! Didn't give me the EPC junk again. Still have the coolant sensor light tho
 Pouria Savadkouei
 Michael S. Palmer
bikerbird0202
Dec 15, 2007 04:08 PM
Quattrould
Feb 17, 2004 02:21 PM
Quattrould
Feb 17, 2004 02:14 PM
swinmachine
Sep 24, 2003 12:46 PM
- GT Style -
Apr 18, 2003 07:33 PM
