Thoughts on how to reduce/eliminate detonation without getting extreme (ie water injection)?
Old Jul 16, 2008 | 03:16 PM
JohnLZ7W's Avatar
Default Thoughts on how to reduce/eliminate detonation without getting extreme (ie water injection)?
I still get a bit of pinging even with the new fuel pump, it's been there before the pump went bad anyway. I've got an FMIC and the evoshield for additional cooling and I run copper plugs at one range colder (BKR7E).
Anything else I can do without getting into water/meth injection? Would running an adjustable FPR make any difference (I've got the 4-bar with a ****)?
Programming is fairly conservative, just a single 91 octane program from OCT.
Thanks!
Old Jul 16, 2008 | 03:22 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Oct may be aggressive timing wise...>>
You really shouldn't be pinging John...Not enough that the Knock sensors coudn't handle. Maybe some Carbon build-up on the pistons/Valves? Might be time for a good top end flush (Seafoam etc)!
Old Jul 16, 2008 | 03:25 PM
JohnLZ7W's Avatar
Default It's not really bad, right around when boost spikes in 3rd gear I get just a little bit
that is audible, doesn't happen all the time. Didn't see much buildup on the valves when I pulled the manifold recently but I guess the pistons could be another story. Suggestions on a good top end flush? Have read enough slightly scary stories about seafoam that I don't really want to try it. Maybe spray some water into a vac line?
Old Jul 16, 2008 | 03:31 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Google yeilds some other options...
I'd probably lose the copper plugs too....:-)<ul><li><a href="http://www.google.com/search?sourceid=navclient&amp;aq=t&amp;ie=UTF-8&amp;rls=GGLD,GGLD:2005-14,GGLD:en&amp;q=top+end+engine+cleaner">http://www.google.com/search?sourceid=navclient&amp;aq=t&amp;ie=UTF-8&amp;rls=GGLD,GGLD:2005-14,GGL
Old Jul 16, 2008 | 03:42 PM
JohnLZ7W's Avatar
Default Hmm, was hoping the copper would yield better heat transfer than the platinums
might be time to finally try the iridiums.
edit: and I stopped trusting most of the auto advice on google after people started dumping sand into their intakes
Old Jul 16, 2008 | 03:44 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default My experience...>
with the Iridiums was excellent...RoberTT and Hans will echo that as well I'm sure!
Think about getting the injectors blueprinted as well...You might have a weak spray pattern on one or more...Cheap as I recall..
Old Jul 16, 2008 | 03:45 PM
JohnLZ7W's Avatar
Default injector blueprint was something I had considered awhile back
will add a set of Denso's to the shopping list
Old Jul 16, 2008 | 03:48 PM
joe@vwvortex's Avatar
Default Have you logged your timing pull? Also might want to try some higher octane gas - 100 octane
and just see if it is really detonation. Torco Octane Concentrate works as well - it's not an octane booster.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 16, 2008 | 03:53 PM
JohnLZ7W's Avatar
must.... resist.... 100 octane... crack addiction....
Old Jul 16, 2008 | 04:01 PM
l33tt's Avatar
Default Got some last weekend. ONLY $6.99/gal.
Never follow.
