All TT gurus, please help.
Old Jul 18, 2008 | 03:58 PM
Michigan TT's Avatar
Default All TT gurus, please help.
will a DV loose boost with a pressure gauge pumping through the vacume end? I put one on my 45 day old APR R1, and it went from 15# to 10# in 7 seconds. the higher the pressure, the faster the leak down. Is this normal?
Old Jul 18, 2008 | 03:59 PM
sorry about the spelling
Old Jul 18, 2008 | 04:21 PM
voo, anyone? anyone? voo doo economics
Old Jul 18, 2008 | 04:41 PM
JohnLZ7W's Avatar
Default I don't think you're supposed to tap the DV line for a boost gauge
That isn't a constant source of vacuum since it runs through the N249 valve. Most people tap the FPR line.
Old Jul 18, 2008 | 04:58 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Shouldn't drop pressure like that......>>
When tested with a pump, though the last R1 I checked did that too. You really want it to hold pressure with little or no bleed-down. We took it out because it was honking. It isn't turning out to be a very good DV based on many reports..
Old Jul 18, 2008 | 05:41 PM
oldseTTer-WWKD's Avatar
Default POS!!!! Had (including replacements) 3.............
All honked or leaked APR made it good in the end after much todo.
Get a piston type!
Old Jul 18, 2008 | 06:54 PM
PracTTical's Avatar
007 FTMFW
Old Jul 19, 2008 | 03:19 AM
thank you sir, that is probably one of the problems.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 19, 2008 | 03:21 AM
the n249 held pressure on its own
Default This is the one he is talking about there are lots of choices
but this seems the most popular one.
Comes in silver or black.<ul><li><a href="http://www.forgemotorsport.com/content.asp?inc=product&amp;cat=0006&amp;product=F MCL007P">http://www.forgemotorsport.com/content.asp?inc=product&amp;cat=0006&amp;product=F MCL007P</a</li></ul>
