New 3.2 Owner: Now how do I soften my suspension?
Question: Are there any suspension kits available for the VR6 Quattro that offer a somewhat softer ride? Did a search but found mostly info for 1.8T models. Love the handling but the ride on L.A freeways is a bit "jouncy". Not interested in lowering at this point, just a little smoother ride.
Thanks in advance
The Koni FSD is supple, but not soft. I have a set: love them. And, some report that the spring perch is at the wrong height, making the car sit a bit higher. Mine don't, but check them if you buy.
dale
I've considered the FSDs, but am worried about the ride height issue and possible spring perch problems. Our 3.2s are already higher than other TTs; definitely don't want to jack it up any more. Michael at Pure Motorsports (purems.com) recommends Koni Sports for use with stock springs. A more comfortable set-up, he feels, than Bilsteins. And you can adjust rebound, which might help reduce the jouncy-ness.
You could go with the FSD/Eibach kit. It will lower the car some. The question is whether you'll need camber adjustment at that point. I just don't want to deal with that complication; hence my intention to retain stock springs.
Unfortunately, suspension choices for the 3.2 aren't clearcut.
