VAG-COM Guru's
Old Jul 19, 2008 | 07:27 AM
LSZ's Avatar
LSZ
Member
Default VAG-COM Guru's
Is there a vag-com measurement parameter that tells you whether the haldex clutches are engaged? Is it possible to monitor in real time the status of the rear wheel drive? This is for a 2002 TTQM.
Old Jul 19, 2008 | 07:46 AM
PracTTical's Avatar
Default yup>>
go to the output readiness test in the Haldex/AWD controller..
you should be able to run through the test and it will tell you that the back wheels are engaged.
you can also use the haldex 'parking lot' test, just as reliable.
see the TT FAQ for that one.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1389261.phtml">TT FAQ</a></li></ul>
imolatt
Oct 6, 2005 10:09 AM
|everso!|
Aug 25, 2004 07:12 AM
Colonel Bogey
Feb 20, 2002 05:05 PM
OzChris
May 30, 2001 05:33 PM
rollerskate
Apr 24, 2001 11:25 AM
