disabled aliens, what else do i need to unplug? (had a wiper fluid hose blow off)
Old Jul 19, 2008 | 09:29 AM
adminisTerTurbo's Avatar
Default disabled aliens, what else do i need to unplug? (had a wiper fluid hose blow off)
i used my wiper fluid for the first time after i disabled the aliens by plugging the line, and unhooking/removing them. found that it blew a hose off. not sure which one yet. i'm about to go remove the wheel liner and find out.
is there a separate pump for them i need to unplug?
thanks...
Old Jul 19, 2008 | 09:56 AM
M power this!'s Avatar
Default I'd guess your plug popped out. There isn't anything else needed.
i plugged it with one of those rubber plugs you get from the hardware store that has a screw built in to expand. I expanded it until it was abit tight and then put a big zip tie around the outside to give it something to push against.
Old Jul 19, 2008 | 10:01 AM
MarTT's Avatar
Default I routed mine into the front grille so I could surprise passers-by. j/k :-)
Could work, though. Didn't I see a post about that some time ago?
Old Jul 19, 2008 | 10:15 AM
Default i used a bolt that fit super snug and then put a hose clamp on it...
we'll see. i'm going to check it out now. i think maybe it was just a freak coincedence and another hose came off...
Old Jul 19, 2008 | 10:39 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default The bottom pump is the alien one...>
Just unplug it, but plug the water line too so it doesn't siphon..
<img src="http://images32.fotki.com/v1109/photos/7/7305/111929/DSCF0006-vi.jpg">
<img src="http://images34.fotki.com/v1077/photos/7/7305/111929/DSCF0008-vi.jpg">
Old Jul 19, 2008 | 11:52 AM
Default thanks, that was the problem
the motor shot out from the mount essentialy. should be good to go now.
Brayton
Apr 30, 2013 05:00 PM
ZX
Audi Original "S" Cars
9
Jun 25, 2007 05:59 PM
Blue2
Sep 11, 2004 09:19 AM
94audi100s
Audi 100 / A6 (C4 Platform)
Sep 8, 2004 08:20 AM
DNA930
Mar 13, 2003 08:14 PM
