What is the trick?
Old Jul 20, 2008 | 02:18 PM
TT Oregon's Avatar
New Member
Default What is the trick?
So what is the trick to get the shift **** screwed down tight with the rubber shift boot? I'm putting in a new one and it is challenging me. :-)
Old Jul 20, 2008 | 02:23 PM
AxeYrCat's Avatar
Member
Slide shift boot down, tighten shift ****... ???
Old Jul 20, 2008 | 02:29 PM
MarTT's Avatar
Default Here's the **** install from Raffi:
<ul><li><a href="http://www.autoaesthetics.com/Pages/03_Knobs/aa-****-instal.pdf">Check it out.</a></li></ul>
Old Jul 20, 2008 | 02:52 PM
TT Oregon's Avatar
New Member
Default Thanks!
My new **** is one piece so I think the soap may play a key role in getting the **** screwed down tight. It is close but not quite there yet.
Old Jul 20, 2008 | 03:54 PM
JohnLZ7W's Avatar
I couldn't get mine to stay where I wanted it so used a bunch of blue loctite, problem solved
Old Jul 20, 2008 | 04:03 PM
TT Oregon's Avatar
New Member
Default Re: I couldn't get mine to stay where I wanted it so used a bunch of blue loctite, problem solved
All I'm trying to do here is make a couple more turns of the **** to tighten it up. It is really tight around the boot but I'm now thinking a bit of lube will do the trick. I might try to pull off the shift ring and get to it underneath as well.
Old Jul 20, 2008 | 05:28 PM
J. Patterson's Avatar
Having that problem now . Guess I don't have to search for a fix. Thanks :-)
AreenS4
May 8, 2006 12:17 PM
4labs
Audi allroad
Apr 16, 2004 05:53 PM
Chuck-S4
Oct 28, 2003 05:15 AM
JeffPGH
May 23, 2002 08:21 PM
MJD
Feb 23, 2000 01:31 PM
