Ok Steve, spending money for real this time.
I recently installed KW V3's in my quest to eventually turn my car into an almost dedicated track car (only as street legal as it has to be).
I already had the KMAC stage 1 camber/caster strut tower kit, but it was absolute garbage from the start, and now its absolutely useless since its not compatible with any strut with valve adjustment in the top of the tube. I'll be buying a ground control kit. Now, they have 2 options. One is drop in, w/ 1.8 additional degrees of adjustment. The other requires modification of the strut tower (not a problem), and offers 3.5 degrees of adjustment. I can get either for roughly the same amount of money, so it really comes down to how much adjustment I want/need.
I'd rather over-do it than have to upgrade again in a year or two. Will I ever see a need for an additional 3.5 degrees of camber?
If anyone can fill me in more on whats allowed/not allowed for SCCA racing, that'd be much appreciated.
Trying to digest this, but its a lot of reading, and I'm usually a bit burned out at the end of teh day when I have time to actually sit down with it.
http://www.scca.com/documents/Club%20Rules/Production.pdf
-2.7 left and right front camber
0 Cross camber
7 left and right caster
0 degrees of toe
rear -1.3 camber
.07 left and right degrees toe
.15 total toe
I could still get a little more camber out of the front but not much more, hope this helps
