Car won't start...thankfully I'm not joining the flatbed truck (yet) ...>>>
Old Sep 9, 2008 | 01:50 PM
TTomahawk's Avatar
Junior Member
Default Car won't start...thankfully I'm not joining the flatbed truck (yet) ...>>>
since it happened at home and I have a beater.
03 model, 44k miles, OEM Battery still
Now this is 2-3 days after I drove it around.
When I try to start the car it's giving a series of clicking sound almost like an AK47 firing but not that loud (I'm sure you guys have some technical word for it). All the other stuff is firing up, radio works, cabin light works...didn't try headlights.
You guys think it's the battery even though other stuff is working?
Should I buy a voltmeter and test it out or just jump start and change the battery?
TIA!
Old Sep 9, 2008 | 02:01 PM
BlueChip's Avatar
Default It's the battery.........
Have heard that sound many times in my life and it's always the battery. Strong enough to run the accessories (not for long) but not enough juice to start the car. When the clicking stops the battery is completely dead.
BC
Old Sep 9, 2008 | 02:02 PM
TTomahawk's Avatar
Junior Member
Default Luckily I haven't fired it too much...the radio also went in safe mode...>>>
haven't done this before ever? can I jump start and take it to a mechanic?
Old Sep 9, 2008 | 02:07 PM
alms_lefko's Avatar
replace yourself... easy
Old Sep 9, 2008 | 02:12 PM
TTomahawk's Avatar
Junior Member
erm..not sure if I can manage that.
Old Sep 9, 2008 | 02:25 PM
TTomahawk's Avatar
Junior Member
Default Ok found Jeff's write up..Is this an exact fit so I don't need anything else to secure the battery?
<ul><li><a href="http://www.sears.com/shc/s/p_10153_12605_02833347000P?vName=Automotive&amp;cN ame=Batteries+%26+Chargers&amp;sName=Automotive+Ba tteries">Battery</a></li></ul>
Old Sep 9, 2008 | 02:36 PM
alms_lefko's Avatar
I'm not sure which are direct fits and which arent... maybe someone else can chime in if that one is
Old Sep 9, 2008 | 04:05 PM
blackfnTTruck's Avatar
Default Mine wouldn't start one morning, and it would actually crank pretty well, but when I checked....
my battery voltage, it was OK until I started to crank, then it dropped to about 10 volts, not enough, apparently to turn it over. Try jump starting it.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 9, 2008 | 06:01 PM
TTomahawk's Avatar
Junior Member
but my battery is 5 years old.....hasn't it outrun it's cycle?
Old Sep 9, 2008 | 11:15 PM
kingfishgrapejam's Avatar
Sears link was down but Autozone stocks an exact fit.
