paging anyone who knows how to work this scangauge >
Old Sep 9, 2008 | 05:13 PM
TTwizted13StrtRcr's Avatar
Member
Default paging anyone who knows how to work this scangauge >
so im told it computes HP.... what is display on the scangauge for HP?
also to steve... did you pre-program this for the TT's gas tank and stuff? or does that still need done?
thanks!
Old Sep 9, 2008 | 05:20 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Get into the gauge function and...>>
Push one of the 4 gauge buttons until "HPR" comes up. It'll be 6-10 hp at idle.
You'll have to do your own Gas caibrations...Car specific.
Read the manual!
Old Sep 9, 2008 | 05:22 PM
Member
Default yea i did read the manual...
it said once plugged in i have to type in fuel information... i was thinking in my head, 'hey its gunna pop up' ...but it didnt thats why i was wondering if you did it or not.
my 4 gauges i have up are voltage, intake air temp, water temp, and hpr.
are there more vital gauges i should be aware of?
Old Sep 9, 2008 | 05:29 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Those are good...>>
STF and LTF (fuel trims) are the 2 block 32 readings and good to check every now and then..(for MAF health)
Old Sep 9, 2008 | 05:31 PM
Member
whats the normal readings for those blocks?
Old Sep 9, 2008 | 05:35 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default With a **** and 4 bar...>>
LTF or "Partial throttle" in VAG (Most valuable) should be around -4% but will vary from -5 to +5% depending on MAF
Old Sep 9, 2008 | 05:45 PM
Member
so LTF should rean around -4, and the STF shoulr be between -5/+5?
Old Sep 9, 2008 | 05:47 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Well,what I said....>
Is both will potentially range from -5 to +5.
Usually the STF will be a bit closer to Zero than LTF's as the 02's are controlling the fuel
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 9, 2008 | 05:49 PM
Member
Default gotcha... makes a little more sense to me now
thanks again
TTwizted13StrtRcr
15
Sep 5, 2008 10:26 AM
box_of_partS4
Apr 5, 2006 10:47 AM
virtuapete
Oct 6, 2005 03:16 PM
Tee x2
Sep 14, 2004 06:29 AM
