coolant question - VW/Audi G12 Plus, 1.5L bottle vs. Pentosin Pink G12 Lifetime Coolant
Old Sep 10, 2008 | 12:04 PM
Cruzad3r's Avatar
Default coolant question - VW/Audi G12 Plus, 1.5L bottle vs. Pentosin Pink G12 Lifetime Coolant
so since my last TB replacement, i was using this Pentosin Pink G12 Lifetime Coolant.
<img src="http://www.germanautoparts.com/displayimage.php?file=000125150307G4">
i'm not sure if the pentosin is better than the vw
<img src="http://www.germanautoparts.com/displayimages.php?file=19M7F083A2221608G9">
has anyone used the vw coolant? both need to mix with water. which bring me to the next question is there coolant available that i don't have to mix before i use it? thanks for any info
Old Sep 10, 2008 | 12:32 PM
msauve's Avatar
Default You don't have to mix...
you can just add equal amounts of antifreeze and water, it will quickly get mixed in the cooling system. Why pay for shipping/packaging water?
Some people claim the VW stuff is made by Pentosin, but I've never seen any documentation to back that up.
I think it's more likely to be BASF Glysantin G 30, and that the newer VW G12+ is Glysantin G 30-91. G 30 is pink, like the older VW G12, G 30-91 is violet, just like the newer G12. Pentosin AFAIK is only available in pink. I believe that VW changed colors to help avoid confusion with some other manufacturer's pink-colored OAT coolants.
Old Sep 10, 2008 | 01:02 PM
Cruzad3r's Avatar
Default well the shop that i had my TB changed said he mixed it... i didn't really trust him but i go along
with it. anyway... i'm going to try the WV.. i wonder what my coolant going to be like after i mix pink with purple ...
so bottom line, do i have to use distilled water or i can just use the regular stuff; pour that straight into the reservoir and let the system mix by itself?
again thanks for the clarification.
Old Sep 10, 2008 | 01:16 PM
msauve's Avatar
Default Use distilled...
or deionized, or RO (reverse osmosis) water. It's cheap enough, and you won't get any minerals settling out.
The best way to check to see if the mixture is correct is to use a refractometer, but a simple $5 "floating ball" type from your FLAPS will work well enough. (they're available for testing both ethylene glycol and propylene glycol based antifreeze - G12 is ethylene glycol)
Old Sep 10, 2008 | 01:58 PM
Cruzad3r's Avatar
cool thanks
jeffkruse
Jan 9, 2017 07:39 AM
a8 snob
Jan 25, 2012 12:06 PM
skl1
Jan 10, 2006 03:49 PM
SpeedyDTP247 CQ+UrS4
Jul 19, 2004 05:30 PM
EhhFour
Jun 29, 2003 05:45 PM
