Anyone ever use the roadster support beams? Also why isn't my after run coolant pump going on?
Do you think it's worth $50 bucks one day?? Or it doesn't stiffen up the chassis @ all?
Anyone have photos of under a roadster with the belly pan off? Or a shot of the additional bracing??
I know a lot of BMW guys use the X brace that comes on convertibles on the coupes and claim it stiffens up the chassis a lot.
>Edit; On the after run coolant pump... I'm not driving my car now, however, I noticed the last two days of driving it that the pump wasn't on when I turned the car off no matter what. Is there a fuse/relay I can check that is known to blow? Is the pump just dead @ 86k?? Thanks guys!
#35 & 34 & BIG thanks to marTT!
<a href="http://s8.photobucket.com/albums/a44/godsphantasma/?action=view¤t=diag1.jpg" target="_blank"><img src="http://i8.photobucket.com/albums/a44/godsphantasma/diag1.jpg" border="0" alt="Photobucket Image Hosting"></a>
typically:
when the fans quit it's the module
when the pump quits, it's the pump
"after run" doesn't really describe this pump!
it runs all the time (the engine is running) plus 10 more minutes each time the ignition is switched off
70-ish, maybe 80k miles of useful life has been my experience with 'em
I don't know what is going on though. It just seems like every time my buddy stops driving his Corrado VR6- his fans pop on after EVERY drive, like my car will be overheating after a good run, or at a stop light, and the fans wont kick on...
So try fan switch first?
Is there a way to test the after run coolant pump?
Could this be the reason my car has been heating up @ stop lights ect? I'm pretty sure the turbo gets coolant circulated by the waterpump like the rest of the car though...
Maybe different sub-frame on roadster vs. coupe?
<img src="http://images40.fotki.com/v1239/photos/1/168597/848842/DSC02987-vi.jpg">
