Installed Bilstein HDs a few months ago..kinda harsh ride...>>
Old Sep 11, 2008 | 01:36 PM
heinzboy57's Avatar
Default Installed Bilstein HDs a few months ago..kinda harsh ride...>>
I installed a set of Bilstein HDs about 2 months back. My 2000 TTQ had 109k miles on it with the stockers (!)..anyway..the ride was pretty brutal.
Installed the shocks/struts with stock springs and got an alignment. Also should note I got new tires a few months before that. The ride was nice and sporty..sportier than I would have imagined..
but over abrupt bumps, it feels too harsh to be right...what could be wrong here (if anything)?..
It's kind of annoying..but otherwise, the car handles very nicely.
Old Sep 11, 2008 | 03:03 PM
Russ Scott's Avatar
Default normally this combination rides pretty nicely>> a couple things->
these dampers are harsh at first, Bilsteins require a break in period when new... several hundred miles should be logged before they'll hit their "ride" optimum
could your tires be overinflated?
I had this set up and found it so harsh I pulled the dampers back out and sold them to ZZcett aka Scot
years pass, and Scot loans me his car for a week while Sandra and I are in Hawaii...
WTF was I thinking about? "this thing is freakin SMOOTH!!!"
Old Sep 11, 2008 | 03:34 PM
TTinCT's Avatar
Rest In Peace
when was the last time you changed your strut bearings and bushings...
Old Sep 11, 2008 | 03:38 PM
heinzboy57's Avatar
hi. I changed 'em when I put the HDs in..shoulda mentioned that..
ITALSKIER's Avatar
if you think the HD's are harsh you def. would not like the sport ones..... [-)
Old Sep 11, 2008 | 03:42 PM
heinzboy57's Avatar
Default really?!..interesting..i've prolly put at least 1500 miles on em..36-37psi..>>
..i guess i'll see whether they change as the miles go on..
I'm glad I'm not the only one that thought it was surprisingly harsh for Aftermarket shocks/struts with stock springs..
Then again, I don't know what a brand new 2000 TTQ drove like off the show room...just a used 8yr old car with 100k miles on it..
Thanks for your reply
Old Sep 11, 2008 | 03:45 PM
heinzboy57's Avatar
Default ..not that I don't enjoy it..just needed to know if that was 'normal'..>>
as i mentioned below, I didn't know what a TT suspension 'should' feel like..i bought the car with the original shocks/struts with 100k miles..all i knew is that they needed replacement.
I liked the sporty 'stiff' ride it gave down the road..but sharp bumps and such don't get dampened at all..anyway..hopefully it'll get a little bit better with some miles on 'em.
My other car has tein basic coilovers and it's low..ride is firm, ..the bumps might be the same..maybe a little bit less dramatic..
maybe it's my tire pressure..
Old Sep 11, 2008 | 03:46 PM
TTinCT's Avatar
Rest In Peace
Default unless the bushing is not seated right>>>
on the strut tower, they should be fine..
It is sportier....but every ones opinion and expectation is different...personally, i love my sports and Eibach springs..
if you were expecting softer...or stock....it is not that.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 11, 2008 | 03:47 PM
heinzboy57's Avatar
Default ..maybe i'm putting in too much tire pressure...
i looked at the gas cap for #s..but those could be for full capacity/luggage...any input?..
yar..
Old Sep 11, 2008 | 03:50 PM
heinzboy57's Avatar
Default i think i was expecting 'stock'..for whatever reason..
which was why i was surprised..but hey, i don't mind the sportiness now that you guys' have confirmed it should feel a bit sportier..
thanks again for the input.
