After 81000 miles replaced original front rotors with drilled rotors today...
Old Sep 12, 2008 | 06:21 PM
TTGram's Avatar
Member
Default After 81000 miles replaced original front rotors with drilled rotors today...
The front rotors were down to 22mm. The front pads were down to 1/8 of an inch of lining. My pad warning light came on at TTeast and I have driven 2000 miles since. New pads are Mintex red box. Was hoping to change all four rotors today, but the rotor holding screws had to be drilled out. Both screw heads came off leaving the threaded part in the hub and had to be drilled out and tapped.
Then the first stainless brake line I replaced
was leaking from the fitting crimp. At first I thought it was leaking because I had dirt in the fitting but after taking it apart and tightening it several times saw that the fluid was coming up from under shrink tubing that was over the lines crimp. So I put the old line back on and didn't try the second one. So after 6 hours of work called it a day.
Old Sep 12, 2008 | 07:07 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Good mileage out of those rotors!...>
You should like the Mintex too Ted. Good feel, Low dust..
Old Sep 14, 2008 | 08:18 AM
beltway's Avatar
New Member
what brand rotors did you choose?
kkii9
Jun 11, 2006 06:49 PM
Dr.Aronis
RS 6 Discussion (C5)
22
Oct 13, 2005 11:32 PM
sbmellen
Jan 22, 2004 04:47 AM
mike*green
Jun 2, 2003 12:26 PM
Mike O.
Apr 4, 1999 06:23 AM
