Ball joint replacement > front end clunk? The verdict:
Old Sep 13, 2008 | 01:00 PM
SparTTan's Avatar
Default Ball joint replacement > front end clunk? The verdict:
Nope. The clunk is still there when turning in reverse. Replacing the ball joints didn't get rid of it. I asked the shop doing the alignment to look it over and they said they didn't see anything that would be causing it.
So the mystery continues...
Old Sep 13, 2008 | 01:06 PM
TTinCT's Avatar
Rest In Peace
Default Rich, you ever replaced the rear control arm bushings???
They do have a tendency to wear......more so if you have an aftermarket suspension...just a thought.
Old Sep 13, 2008 | 01:10 PM
SparTTan's Avatar
Default The rear bushings on the front control arms?
No, never replaced those. But do those have any movement when turning the steering? Seems they only move up and down with suspension travel -- would they have any affect to the steering?
I need to see a diagram...
Old Sep 13, 2008 | 01:51 PM
TTGram's Avatar
Member
Default When replacing my front rotors yesterday I noticed stress cracks....
in rear bushing on front control arms. They were worse on passenger side. Looks like time to get Defcon upgrade.
Old Sep 13, 2008 | 04:25 PM
GorTT's Avatar
Default two things >
First, the rears don't have 'much' to do with the defcons, other that that if you are replacing the rear bushes, you have the control arms out and it's easy to do the upgrade at the same time - which I presume is what you meant, and
Second, the rears cracked/fatigued won't cause the knock he's describing.
Old Sep 13, 2008 | 04:32 PM
GorTT's Avatar
Default I wouldn't think it would have been the ball joints >
you need to think about what's moving in that situation - could be the drive shaft/a link in there, or the struts, the tie rods, the end links, the swaybar mounting points, or even the subframe bolts if it's been screwed with and something has stripped. Does it knock only once when you back up or is it repetitive?
Old Sep 13, 2008 | 05:06 PM
SparTTan's Avatar
Default It's usually one larger knock and then sometimes a second, quieter knock
Only occurs when turning in reverse, such as pulling out of the garage in the morning or backing out of a parking space. It will sometimes, but not always, happen when pulling forward and turning, such as pulling forward from a parking space. Then it won't happen again until the next time I park the car.
I've replaced tie rods and ends, strut bushings and bearings, wheel bearings, and now the ball joints.
I replaced my steering rack about a year and a half ago, which involved lowering the subframe, but retorqued everything to spec and had a very reputable shop do the alignment afterwards, so I would assume no problems in that area.
Old Sep 13, 2008 | 05:17 PM
TTinCT's Avatar
Rest In Peace
Default Not sure i agree>>>
100%.....as that rear bushing has some very strange angles to account for, not to mention the metal sleeve in the middle of that bushing...
I will tell you my car "popped" everytime i backed it up and turned the wheel....once i replaced with a poly setup, it went away completely....
Just my two cents
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 13, 2008 | 05:44 PM
sTTevo's Avatar
Default My TT did not have this issue until some tine after defcons with new OEM rear bushings installed.
I suppose the front LCA rear bush could have developed a problem several months later.
Old Sep 13, 2008 | 10:28 PM
MaxHedrm's Avatar
Mine does the same, but needs a bunch of refreshing, so I've not hunted it. It's like it settles.
