Well glovebox latch broke after 75,000 miles - I knew it was just a matter of time...
Old Sep 14, 2008 | 01:17 PM
PMrider's Avatar
New Member
Default Well glovebox latch broke after 75,000 miles - I knew it was just a matter of time...
The handle came out in my hand like the plastic hinges had melted or something. It was also coated in white lithium grease which subsequently got all over the interior before I realized it was on my fingers. I'm glad I always carry a small microfiber cloth in the car.
Time to go to the Home Despot for some socket screws and speednuts.
Old Sep 14, 2008 | 01:30 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
That's only a penney a mile!
Old Sep 14, 2008 | 03:38 PM
TTBella's Avatar
Junior Member
Default Alway's look on the bright side of life..do doom.
Q's up, Monty Python song.
Old Sep 14, 2008 | 05:05 PM
tooofast's Avatar
New Member
Default is there a write up on how to fixe these? Mine went today
Anything would be great as just looking at it i dont know where to start.
Thanks
Dave
Old Sep 14, 2008 | 05:52 PM
Chuck's Avatar
Junior Member
8+ yrs, 50K miles, and mine is still going strong, which is why I never open the damned thing!
Old Sep 14, 2008 | 09:10 PM
bobkay's Avatar
Default Re: is there a write up on how to fixe these? Mine went today
I managed to get mine open by removing the panel on the passenger side dash. From in there you can get at the button that's holding it closed. It is closed isn't it?
;o)
Bob K
Old Sep 15, 2008 | 12:51 PM
tooofast's Avatar
New Member
well the handle fell off in my hands and looked like it had been put on with a big wood screw as a pivot point. In order to get what looks like the lining to separate from the door i took out the six or eight T25 torx screws (lining and door now separate) and then could see where the 4 bolts held the locking section to the upper door lip itself. I removed them and did a better temporary fix on the latch with a small bit if stainless steel acting as the lower pivot point rather than the plastic. All was going well (famous last words) until i reached into the glove box to put one of the screws in the back in and must have pressed down on it too hard There was a snapping sound and the two little gas pistons came apart in the back and it all went pretty much pear shaped at that point. I ended up taking them out so I could at least close the glove box and think im going to have to pull the dash apart to get it all back together.. Did you see the post where I asked where to get the Bentley book !!!
ESN
13
Sep 28, 2006 09:07 PM
BOOSTD
Jul 8, 2005 02:12 AM
canta4dit
12v V6 Discussion
May 10, 2004 06:41 AM
Tept
Jul 24, 2003 04:07 PM
StormChaser404
Apr 5, 2003 06:17 AM
