Air-condition Vents-spitting out Foam Particles
Old Sep 15, 2008 | 11:54 PM
LonelyTT's Avatar
Default Air-condition Vents-spitting out Foam Particles
My car starts spitting out foam particles everytime I turned on A/C. It's not very serious yet, just few particles each time I use the A/C. Any suggestion how to solve this? Anyone here with the same problem.
Thanks.
Old Sep 16, 2008 | 02:15 AM
Astronut's Avatar
Default Mine has been doing that for some time now
like a couple years. It spits out small particles and big chunks. I have to remove the vent pods occasionally to get the pieces out. The foam almost disintegrates to the touch.
No idea where it's from. Figure there is foam in the duct work somewhere that has become brittle with age. I've just been living with it. Doesn't seem serious enough to be worth tearing the dash apart to locate it.
Old Sep 16, 2008 | 03:01 AM
jimmyTT01's Avatar
Default Vw used to have a foam on the flapper door which opened and closed>>
to push air through the heater core or when the AC was on it was open and it bypassed the core. But eventually the door foam would dry up and fall off, creating a pieces or chunks in the vents. Dunno if this is the same idea as VW. Hope not, cause I redid the door in my 1990 Jetta and it was a pain.
Old Sep 16, 2008 | 03:55 AM
Astronut's Avatar
Default Yeah I did a search on this a while back
and that is what I found as the stated cause. I run the A/C almost exclusively of the year so that would make sense.
Old Sep 16, 2008 | 06:11 AM
JustJeff's Avatar
there is cheap-o gray foam around the opening of the vent inside the dash. Pull the vents-rplc foam
Oembaloem
20
May 19, 2019 07:18 AM
QFR7
Q7 MK 1 Discussion
Oct 15, 2013 10:29 PM
smithy
Aug 15, 2008 03:47 AM
NSX JR
Jun 25, 2004 05:58 AM
Norcalguy
Oct 31, 2001 11:52 PM
