Bolt question. R'cvd my order and though I am sure of which bolts to use, I am unsure of which nuts
Checked with Impex and apparently the strut bolts take regular nuts (non-locking). For some reason, I find that hard to believe.
So, I checked the control arm nuts and they are both locking and a bit taller (taller=more holding strength?). I have the other nuts from the control arms bolts I used as strut bolts. Can I just re-use them, or would you recommended what Impex sent and use some locktite?
Thanks.
So, I took the bolts used in the rear bush and compared them to the strut bolts. They looked nearly the same, so I switched them out.
Then, I thought better of it and ordered the correct bolts. But World Impex sent nuts which I just cannot believe are correct. I am probably wrong, but why wouldn't those nuts be lock nuts?
So, am just asking about the nuts is all.
Thanks.
