Those of you with 42DD downpipe for the 225, is there a significant...
Old Sep 16, 2008 | 07:20 AM
Room4TU's Avatar
Default Those of you with 42DD downpipe for the 225, is there a significant...
increase in HP gains noted than before installation? Trying to decide if I should shell out $650 for a new downpipe. TIA
Old Sep 16, 2008 | 07:34 AM
MaD MaTTer's Avatar
i defintetly felt a noticeable increase with mine. i got the test pipe with it.
Old Sep 16, 2008 | 07:51 AM
Room4TU's Avatar
Will i be able to pass Texas state inspection and emissions with a test pipe?
Old Sep 16, 2008 | 08:08 AM
debashis's Avatar
Default i don't have one, but i did some reading as i was also contemplating getting one>
from what i've read here on AW, there is a noticeable improvement in performance! check out joe's article on vwvortex if you haven't already!
Old Sep 16, 2008 | 08:36 AM
DynomiteTT's Avatar
Depends on if you go to the right place....
Old Sep 16, 2008 | 08:53 AM
ITALSKIER's Avatar
Do it...if you can.......yes,there is a noticable difference....
Old Sep 16, 2008 | 09:29 AM
graviTT's Avatar
Junior Member
Default I may have noticed little bit of loss down low with the testpipe
<center><img src="http://pictureposter.audiworld.com/115488/imgp2162.jpg"></center><p>
Might be because of large decrease in backpressure, then again I have a very high flowing exhaust setup
Old Sep 16, 2008 | 09:42 AM
joe@vwvortex's Avatar
Default Yes - proven on the dyno.........
<center><img src="http://www.fourtitude.com/news/uploads/Features/014__scaled_600_022.jpg"></center><p>Go here to see the write up that resulted in this.<ul><li><a href="http://www.fourtitude.com/news/publish/Features/article_3024.shtml">Project TT on Fourtitude dyno's the 42 DD downpipe</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 16, 2008 | 09:43 AM
debashis's Avatar
that's exactly what i was referring to in my reply below!
Old Sep 16, 2008 | 09:51 AM
MaD MaTTer's Avatar
doubtfull, you can always get the catalytic and swap at will
