Any ideas? My AC is blowing luke warm air... compressor is fine..
Old Sep 16, 2008 | 07:25 AM
ZGTT's Avatar
Default Any ideas? My AC is blowing luke warm air... compressor is fine..
and the freon levels are good with no leaks.
My tech thinks it is somewhere between the compressor and the control module... (hopefully not the control module)
anyone else have similar symptoms?
Old Sep 16, 2008 | 07:26 AM
Room4TU's Avatar
I had similar problem in the past turned out it was the fan motor not working anymore.
Old Sep 16, 2008 | 07:29 AM
Scenic Driver's Avatar
Default ...
Could be a faulty high pressure switch or fan control module. Both control the compressor. There is a vag com block for checking if a compressor cut off condition exists, it's in the bentley.
ZGTT's Avatar
the fan for the ac?
Old Sep 16, 2008 | 07:30 AM
Also, there is a test procedure for a/c issues in the bentley
Old Sep 16, 2008 | 07:32 AM
MaD MaTTer's Avatar
check the green fuses by you battery box.
Old Sep 16, 2008 | 07:38 AM
ZGTT's Avatar
checked and they are good. thanks
Old Sep 16, 2008 | 07:39 AM
ZGTT's Avatar
passed the info along Evan - fingers crossed. thanks!
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 16, 2008 | 07:44 AM
Room4TU's Avatar
YES. After I replaced the fan the AC was blowing cold as ice again.
Old Sep 16, 2008 | 07:45 AM
GorTT's Avatar
Default Yes; look at the drivers side fan and see if it's running >
I had that problem once.
