Noob TT owner question?
Old Sep 16, 2008 | 08:56 AM
AudiMick's Avatar
Default Noob TT owner question?
Usually hang out on the A4 B5/ B6 /12v forums.
This is our third Audi (2 A4Qs) but only our first TT.So i am familiar with the cars.
Red 2001 Quattro. 78K timing belt being replaced today (negotiated it as part of the deal).
Couldn't find a 225 in Red locally so this is a 180.
The FAQ is great and has already helped me a lot.
Can't find the answer to this one. What can VAG.com test in the TT cluster? Since its a common point of failure I wanted to check the cluster to see if everything actually works. I don't have an owners manual(plan on buying one and a Bentley) but would like to check all the warning bulbs and gauges etc.
Car is stock not planning on doing anything other than chipping it in about 5k miles maybe add the second tailpipe and new valance.
Old Sep 16, 2008 | 11:57 AM
Cruzad3r's Avatar
Default have you used vagcom before? if so, the test are pretty much the same. go to your cluster tab and do
an output test. you can read more about it at rosstech.com
Old Sep 16, 2008 | 01:20 PM
AudiMick's Avatar
Default Had a VAG.com for 7-8 years.
Used it on my A4 a few times but that car has been very reliable.
With all the reports about failing clusters and Audi's totally inadequate response I want to check this car out before I change anything.
Andy Schweers
Apr 6, 2017 12:26 AM
RNALTD
Sep 14, 2009 08:09 PM
MattDesign
Mar 12, 2004 11:31 PM
inlinespeed
Feb 17, 2004 12:33 PM
GreekTTCharlie
Jul 31, 2001 03:07 PM
