For Jeff Bipes, et. al., a "bump up" back to the top . . .
Old Sep 16, 2008 | 11:36 AM
Chuck's Avatar
Junior Member
Default For Jeff Bipes, et. al., a "bump up" back to the top . . .
Jeff, this is in response to your answer to my note about the RJ45 jack in the center console. I hope you can weight in a bit and offer your comments.
Here's what I'm hoping to do. The RJ45 jack on the side of the center console is, for all intents and purposes, useless. I just purchased an iPod/iPhone interface made by XCarlink. I purchased it from the UK (http://www.xcarlink.co.uk), although the actual unit is made in China.
What I'd really like to be able to do is simply plug my standard USB-to-iPhone (iPod) cable into a plug. So, I thought I'd pop out the RJ45 jack, and replace it with a BXT USB A Female jack, which I would ideally connect directly to the XCarlink. I'm concerned about signal degradation, so I'd like to have as few intermediate connections as possible.
So, my questions are as follows:
1) how is the existing RJ45 jack seated? Can I remove this easily and replace it with something else, in this case a USB A Female?
2) has anyone every seen a USB A Female-to-iPod Female connector? (The unit ships with a mini-DIN 8 to iPod Male data cable.) If not, how about a mini-DIN 8 to USB A Female data cable?
<img src="http://www.therpmstore.com/images/audiolink-ipod_pic3.jpg">
Of course, I could just run the supplied cable up through the phone bracket grommets and not make this difficult, but I'm hoping to eliminate the "messiness" of a dangling cable when it's not connected to my iPhone.
Thoughts? Suggestions? Any and all comments welcomed!
Thanks in advance,
Chuck
Old Sep 16, 2008 | 11:57 AM
ttrut's Avatar
Member
Default The 8-pin DIN connector brings more wires out from the iPod than just USB.
so you can't just use a usb extension cable to pass the audio along to the XCarlink.
You need a ipod dock extension cable. Sparkfun sells one <a href="http://www.sparkfun.com/commerce/product_info.php?products_id=8743">here</a>.
<img src="http://www.sparkfun.com/commerce/images/products/08743-03-L.jpg">
Old Sep 16, 2008 | 12:26 PM
Chuck's Avatar
Junior Member
Default I was afraid of that. So it sounds--no pun intended--like I need to use the supplied cable . . .
. . . and stop making myself crazy. I don't think I need any more length (seriously, no jokes there), as the supplied cable will probably be long enough. I wanted a jack as opposed to a dangling cord, but that simply may not be feasible.
Old Sep 16, 2008 | 12:49 PM
ttrut's Avatar
Member
Default Well, you can buy cable ends (on the same website) and make one up yourself or embed an ipod dock
into your dash or something like that. I just offered the extension cable as a low effort solution. I guess it's the grad student in me.
Old Sep 16, 2008 | 04:39 PM
Chuck's Avatar
Junior Member
Default As one former grad student--hmmm, is having an MBA elitist?--to another . . .
You'll hear no arguments on saving a nickle from this corner.
But I contacted SparkFun and it won't work as easily as I thought. I guess I'm back to just running the supplied cable up between the bracket hole and the grommet.
Old Sep 17, 2008 | 09:29 AM
JustJeff's Avatar
you can remove the RJ-45, but you will need to put in an adapter plate of some sort to mount the USB
Old Sep 17, 2008 | 10:42 AM
Chuck's Avatar
Junior Member
Great. Thanks, Jeff. I'll see what works best and take lots pf photos!
Old Sep 17, 2008 | 11:34 AM
JustJeff's Avatar
Default Oh and the new iPhone/iPod needs all *4* USB connections...
make sure you take apart the 12V USB adapter, and wires the outputs to a std. USB female socket, or you will not charge your unit.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 17, 2008 | 04:13 PM
Chuck's Avatar
Junior Member
Okay, now you lost me. I have an Edge iPhone, but I hope this is still pretty self-evident.
aa2by2
Aug 1, 2010 06:13 AM
jd_cincy
A4 (B8 Platform) Discussion
Jun 20, 2009 07:26 PM
tubi
Audi A3 / S3 / RS 3
May 27, 2008 07:03 AM
marc snyder
Dec 23, 2004 10:14 AM
Evan (Vogon)
Sep 21, 2001 05:55 PM
