It was the front subframe bushings all along...
I removed the lower halves of the bushings from the rear corners of the front subframe. The rubber was still bonded to the metal just fine, but it was hard to determine if the bushings were worn. Just for diagnosis purposes, I found some metal washers of the 50mm ID x 64mm OD dimension to install between the lower side of the subframe and the upper side of the lower halves of the bushings. With the bushings shimmed in this manner the subframe rear attachment points are clamped tighter. The result is that I can definitely feel an improvement in the handling.
I am pretty certain that the problem with the handling from 30,000 miles onward has been the fault of worn front subframe bushings. It has been very frustrating that the dealership service department and an independent Bosch service center have not been able to diagnose this problem for the past six years.
Recently, I was quoted a price of over $700 to replace these bushings and perform an alignment by the Bosch garage. They are assuming that they will have to drop the subframe to R&R the upper halves of the bushings. Is this correct, or can the subframe be pried down enough to exchange the uppers? Thanks!
Poor alignment could contribute to vague handling as could issues with the steering rack and tie rods..Tires too..
<img src="http://images5.fotki.com/v63/photos/7/7305/776256/suspension-vi.jpg">
<img src="http://images7.fotki.com/v109/photos/7/7305/1232358/subframe1-vi.gif">
You're also describing a characteristic called Tramlining which is caused by this as well as other factors....The quality of the roads you drive can exagerate this, even on roads that "appear" smooth. Truck traffic subtly (sometimes obviously) alters the road contours.
Dunno.<ul><li><a href="http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=47">Tramlining discussed..</a></li></ul>
Does anyone know if the bushing uppers can be R&R'ed without dropping the subframe?
I dropped my subframe to put the front sway bar in. It was easier than twisting the sway bar in.
I'd be more inclined to think whoever did the steering rack replacement didn't torque the subframe bolts correctly. Not the first time that's happened to folks here. It really is hard to do going that extra 1/4 turn. As a result, you may have worn bushings since things could have been moving.
