KMac recommendation
Old Oct 28, 2008 | 10:16 AM
Krissrock's Avatar
Default KMac recommendation
For someone using H&R springs...which level of KMac are recommended to bring the camber back?
Old Oct 28, 2008 | 10:21 AM
TwisTTer's Avatar
Default I don't think it's needed if lowered less than 1/2 inch. But for springs it would be no more than
1/2 KMAC for sure.
Old Oct 28, 2008 | 10:25 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default H&R will require top and bottom.......>>
as the drop is over 1"
Or adjustable arms on the bottom with more throw like CPT's
Old Oct 28, 2008 | 10:33 AM
Krissrock's Avatar
i think i'm over an inch - so a full Kmac? I don't think the adjustable arms go in enough
Old Oct 28, 2008 | 10:35 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You are....>
3 options:
Full Kmac's top and bottom (toe adjustment possible)
1 set arms on the bottom (No toe adjustment)
Kmacs top, arms bottom (toe adjustment possible)
Old Oct 28, 2008 | 10:41 AM
Krissrock's Avatar
Default I have adjustable arms, and I got an alignment, but they are definitely cambered. So i'll try the
half K-mac and see if those arms can come in anymore. thanks
Old Oct 28, 2008 | 10:52 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Maybe they screwed up....>
Some camber is normal, in fact spec is around -2 degrees. Most every set of arms I've seen have plenty of adjustment to get a seriously lowered car cambered correctly. You do have them mounted on the bottom, right?
Here are some good numbers to shoot for. Dig out your alignment chart and see what they did..
<img src="http://images33.fotki.com/v1140/photos/7/7305/63346/alignment_specs_62708-vi.jpg">
Old Oct 28, 2008 | 12:11 PM
Krissrock's Avatar
yeah, they're on bottom. I honestly think they didn't adjust them at all.
 Pouria Savadkouei
 Michael S. Palmer
VRUM VR6
Jun 14, 2008 05:36 AM
amiro
Nov 5, 2007 11:07 AM
CGTBrad
Apr 10, 2006 11:40 AM
gintaras
12
Feb 16, 2005 06:23 PM
gg117
Feb 18, 2002 03:15 PM
