Tech diagnosis: am getting a chirping noise from the motor upon throttle input...
Old Oct 29, 2008 | 09:11 AM
Europa's Avatar
Default Tech diagnosis: am getting a chirping noise from the motor upon throttle input...
... from idle/zero throttle. It's only when I go from off-throtte to on-throttle, and is only when the engine is cold. Now, I'm 99% sure this is the wastegate, but:
1) assuming it's the wastegate, is this the death knell for the turbo, or is it no big deal?
2) is there anything else it could be?
This is an '02 225 with 55K miles and all the mods in the sig below (except I'm back to the stock DV - diaphragm DVs are just so much quicker).
Old Oct 29, 2008 | 09:35 AM
JohnLZ7W's Avatar
Got a metal piston DV? Is it in backwards? Is the vac line attached to it?
Old Oct 29, 2008 | 10:04 AM
Europa's Avatar
No; stock DV is back in the car and has been for a while.
Old Oct 29, 2008 | 10:53 AM
Horch it's Avatar
you say turbo, death and nil....did you beat up your turbo?
Old Oct 29, 2008 | 11:01 AM
Europa's Avatar
Default Did I "beat up" the turbo?
LOL, yes, the car has been driven hard since new (though no track days).
The question is, *if* it's the wastegate, does this mean that it's dying?
Old Oct 29, 2008 | 11:13 AM
iTTaliano's Avatar
New Member
Default I had almost the exact thing you are explaining happen to my car....
it may not be the same thing but I thought I'd chime in.
Mine turned out to be that the bolts loosened up slightly on the turbo. To be exact, the bolts that connect the downpipe to the turbo. Hence the chirp when it was cold. I guess the metal would expand enough when it was hot to tighten itself up.
I hope yours turns out to be the same, since it was an easy fix :-)
Old Oct 29, 2008 | 11:15 AM
Horch it's Avatar
Default something tells me you looking for a reason foe stage III
but I am not mistaken, the waste gate can be replaced separately....no?
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Not sure why you think it's the wastegate....>
It stays pretty much closed until the N75 taper starts to open it at higher RPM's. Never heard of one chirping!
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 29, 2008 | 12:46 PM
Europa's Avatar
Default Um....
.... doesn't it stay open at idle?
Old Oct 29, 2008 | 12:47 PM
Europa's Avatar
Default Hmm... that's an interesting one.
That could be it. It sounds like a rally car.
