Alignment gurus please chime in
Pros: like the 235 look (was afraid it would cover the rim too much)
Cons: they told me 'all 4 rims are slightly bent, but not bad, they useable.. dont expect car to be totally smooth' (however its smoother now when on the freeway then it was) car does drive better
these alignment specs seem wrong... the guy said 'i couldnt adjust it anymore, the rear toe maxed out'
i have no history on rotations however from previous owner... they may have never been rotated for all i know
not sure if that helps at all...
You did tell them about the slotting, right?
Looks like they ignored that "0" toe up front number you gave them also and went with their machine.
Do you think I should take it back?
I'm mainly concerned about my tires wearing uneaven...
I do plan on gettin adjustable arms... at some point (but probably not in the NEAR future)
If you didn't give them this, half your argument for a re-do goes out the door.
Good luck.
<img src="http://images33.fotki.com/v1140/photos/7/7305/63346/alignment_specs_62708-vi.jpg">
In your best guess, do you think they didn't know about the slotting? Even though not all TT's can be brought to spec are my numbers TOO far off where they should have been able to do more?
