quick DV question, I think...
Old Oct 30, 2008 | 04:53 PM
Silvr_Surfr's Avatar
Member
Default quick DV question, I think...
I just installed a Forge 007 DV on my 225. Was going to wait until I got chipped but it's going to be a while until that happens now. So, car is not chipped so I used the green spring. The engine now feels "bogged down" compared to the stock valve. Almost like the turbo isn't spooling as fast as it did.
Should I add a shim? or would that work the other way?
Thanks, Chris.
Old Oct 30, 2008 | 05:05 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Bogged down?.....>>
Make sure you plugged the N75 harness back in or you'll max out a 5 psi. Green spring should be correct. Check the rest of your install..
Old Oct 30, 2008 | 07:12 PM
Room4TU's Avatar
You will get a slightly slower response with a piston vs. a diaphram DV.
Old Oct 30, 2008 | 08:31 PM
Member
That's it! Man, I'm a sloppy mechanic, er....hack. Thank you.
SilberUrS6
Audi Original "S" Cars
20
Sep 6, 2007 07:20 AM
eg95og
May 27, 2005 10:07 AM
Bluto
Jul 4, 2002 08:24 AM
TTapsale
9
Sep 25, 2001 09:00 AM
Bluto
Apr 29, 2001 12:04 PM
