Wiper transmission/linkage access..>
2) If I turn on the wipers with a dry windshield they will stop working in less then 30 seconds.
Local indie shop says it's a common TT problem related to the wiper linkage (they call it the wiper transmission). They say that the replacement transmissions are an improved version that will fix the problem and hopefully prevent the problem from occurring again.
1) Is this a common problem?
2) Anybody have the procedure documented to gain access to the wiper transmission?
BTW... The Michelin Radius blades have great pin-type mounts that fit the 2004 TT very well.
If anybody knows how to get at the linkage I'd appreciate the info. I'm guessing that I'll crack something if I just go at it ***** nilly.
I have seen some posts on other forums regarding this issue (on other VW/Audi models) but not hte TT and the posts are few and far between.
The work order mentions reinstalling the plenum cover, so that sounds like the access point. Good luck.
The cowl cover I remeber as being pretty straightforward, but don't recall specifics.
