HELP: Transmission oil smell after changed
Old Nov 3, 2008 | 08:57 AM
johnson_7773's Avatar
New Member
Default HELP: Transmission oil smell after changed
I changed my transmission oil yesterday, but when I drove on freeway I smell the transmission oil for about 5 seconds and it is gone. But this morning when I drove on freeway, I smell it about 5 seconds again, I wonder what happend?
I pumped 3 3qts into transmission but the oil did not spill out. I wonder if I don't have enough oil in there? when I fill the oil, I drove my car on the ramp, so my car car wasn't leveled. Is that the problem caused the smell?
Old Nov 3, 2008 | 08:59 AM
alms_lefko's Avatar
Default did you spill any on anything that its burning off? i'd get back under there to make sure>
everything tight/not leaking
Old Nov 3, 2008 | 09:03 AM
OldSchool AG's Avatar
Senior Member
Default "when I fill the oil, I drove my car on the ramp, so my car car wasn't leveled"
uh, yeah, that's a problem. you probably overfilled
Old Nov 3, 2008 | 09:14 AM
New Member
Default So what should I do if i overfilled?
DO I have to get my car leveled and open the fill hole? I will check later to see if I spill the oil on anything.
Old Nov 3, 2008 | 09:17 AM
Senior Member
Default yeah open the fill with the car level.... let any overflow drain out.
odds are some of the excess came out a vent hole and hit the exhaust. but you don't want it overfilled, so definitely drain out any excess that remains.
Old Nov 3, 2008 | 09:23 AM
New Member
Default Thank you so much. Where is the vent hole? so I can check if there has some oil spill out.
Old Nov 3, 2008 | 10:05 AM
Senior Member
not sure...sorry
Old Nov 3, 2008 | 01:05 PM
New Member
Default Re: Thank you so much. Where is the vent hole? so I can check if there has some oil spill out.
I saw some transmission oil spill out around the fill hole.
I leveled my car and open the fill hole about 1/5qt came out, lock again and go for a test drive, it was ok.
Thanks for the help.
 Pouria Savadkouei
 Michael S. Palmer
am_ver
Sep 12, 2011 10:36 AM
pudding
Apr 21, 2010 03:22 AM
N X B 3
Apr 12, 2005 12:24 PM
AW #29529
Oct 5, 2002 10:18 PM
Kep
Jul 14, 2001 11:11 AM
