ESP light staying on for a few days, off again, on again
Old Nov 4, 2008 | 03:18 PM
scoTT la rock's Avatar
Default ESP light staying on for a few days, off again, on again
has anyone here had this happen before?
seems like the ESP light just stays on for a few days. then it goes off and the button works like normal turning it on and off, and then it goes back to the light being stuck on. WTF?
suggestions, stories, or advice?
Old Nov 4, 2008 | 03:52 PM
JohnLZ7W's Avatar
Scan for codes, possibly a sensor on the way out, maybe just a loose connection
Old Nov 4, 2008 | 04:25 PM
blackfnTTruck's Avatar
Had it happen with an oily MAF.
Old Nov 4, 2008 | 05:56 PM
Lowcountry's Avatar
Possible lateral acceleration sensor failure.
Old Nov 4, 2008 | 06:09 PM
J. Patterson's Avatar
Default Likely, that was my experience.
Lots of stuff in search.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1754217.phtml">https://forums.audiworld.com/tt/msgs/1754217.phtml</a</li></ul>
Old Nov 4, 2008 | 06:55 PM
SparTTan's Avatar
Default That or the longitudinal acceleration sensor. Or steering angle sensor. One of them is failing
Usually it will cut in and out for awhile, then eventually fail altogether. Common issue.
As John mentioned, you need to scan the codes to know which one.
Audigrl27
Apr 12, 2016 11:49 AM
changoo
Jun 10, 2011 07:06 AM
changoo
9
Mar 26, 2011 08:39 PM
peruski
Jan 23, 2007 12:49 PM
mobsTTa
9
Nov 3, 2005 06:28 PM
