anyone Change the plastic seats in intake manifold? I've got a cracked one...
and while close it's a little sloppy and will probably crack the insert. No problem since it's already cracked...
Work on it with a sharp chisel....On the plastic. Crack it out, then clean up the threads with a 90 degree pick tool until they're clean. The hex is handy for the re-insertion but you have to be careful and maybe wrap it a few times with some metal tape to fit tighter. What you really need is a 20mm but that unobtanium..The cleaner the threads, the easier the re-insertion. You can pick up the 19mm at Mcmasters..
The VW seat is a few bucks, while the Audi one is MANY bucks. The depth may be slightly different though..
