Eric, ? about your gauges...
Old Jul 15, 2004 | 07:47 AM
shrtbus(w/ cq)'s Avatar
Default Eric, ? about your gauges...
thinking about doing a similar set up (boost, EGT, oil press) but I'm thinking about converting my single din (99.5) set up to two single din units...one holding the concert HU and the other having the three 52mm gauges...
you've got the VDO vision series gauges right? my boost gauge as is now matches pretty well...also, how tough is it to hook up the EGT and oil pressure gauges? TIA
Old Jul 15, 2004 | 08:05 AM
Fraser@PNS now w/S6's Avatar
Default All pretty easy with the right parts
I think that is the right series of gauges.
Oil Pressure. You need a metric t-fitting, VDO sending unit and the pod. The t-fitting goes where the stock sending unit currently is, and then the VDO sending unit and the stock one get pluged back in. There are a few parts extra you need too. I will get back to you about them when I think about them.
EGT. Actually kind of expensive for what it is, you need to get a new bung welded in your cat, OR you cna buy my test pipe that already has a bung for EGT probe. The VDO kit comes with all the stuff you need on this one.
vErSeTiLe
Oct 20, 2004 10:37 AM
Mark P
Nov 20, 2003 07:43 AM
Phil type 951
Jun 25, 2003 04:25 PM
'81 tic-tac
May 15, 2003 03:52 AM
