My car is making noise near the springs/shocks.....
Old Jul 26, 2004 | 10:34 PM
Crazy Quattro's Avatar
Default My car is making noise near the springs/shocks.....
Can anyone help fix this? When i go over a speed bump i sometimes hear this clunk. Also if i turn my wheel as far as it can go it will make a noise also. All this is happening to my front passenger side wheel. Its been there for awhile but its just now bugging me.
Old Jul 27, 2004 | 12:18 AM
FBAnder's Avatar
Default check the control arms? Had front, passengers replaced...
they made a clunk noise while over bumps and turning. Also think the front, driver's side is (are) going to but Laurel can't find the source of the noise...
Old Jul 27, 2004 | 03:51 AM
PaulW's Avatar
Default Agreed, probably a control arm....you might consider buying a whole set
a lot cheaper, about $450 for eight front control arms and tie rod ends. Check ebay
Old Jul 27, 2004 | 04:23 AM
gription's Avatar
Default Did you check for...
a pedestrian stuck in the suspension somewhere?
Old Jul 27, 2004 | 04:49 AM
PNS Lazy Bastage's Avatar
Member
Default Who did your suspension....
.... I bet you $5 its the top bolt on the shock tower not tight. When it is not tight it will vibrate around and get progressively worse. It will eventually oblong the hole and you will need to buy shock 'hat' (I forget what it is called).
Old Jul 27, 2004 | 05:14 AM
PlainRuss's Avatar
Member
Default It's tight Mr. Smarty Pants.
Jesel, if you need me to look at it let me know.
Old Jul 27, 2004 | 05:21 AM
Member
Default hahhahahahhahah........
....I didn't know you did his suspension...
<you might want to check it Jasel ;-)>
Old Jul 27, 2004 | 05:50 AM
PlainRuss's Avatar
Member
Don't you have an emissions test to study for? =P
 Michael S. Palmer
Old Jul 27, 2004 | 05:55 AM
TonyPNS's Avatar
Hehe
Old Jul 27, 2004 | 06:14 AM
Member
Yes, yes I do......
