Has anyone here put Nitrogen in their tires?
Old Aug 10, 2004 | 06:45 AM
Studly_1's Avatar
Default Has anyone here put Nitrogen in their tires?
It reduces rolling resistance, seals better against the rim and runs cooler. I just don't know if it's worth the expense of about $5 a tire.
Old Aug 10, 2004 | 07:29 AM
markbradford's Avatar
Rest In Peace
HELIUM reduces unsprung weight!!!
Old Aug 10, 2004 | 07:40 AM
WindyCityS4's Avatar
Default Seals better? Can you explain this, or was that the salesmans explination? My understanding....
is that the pure nitrgoen has 2 advantages. It is "dry" and it is oxygen free (obviously).
The "dry" will help prevent corrosion. The no oxygen prevents oxidation (go figure).
As for rolling resistence....I would like to hear that one. Normal atmosphere is almost all nitrogen already (~78%).
Overall. I would say skip. Not worth $20 to me.
Old Aug 10, 2004 | 07:42 AM
Not hydrogen? It is lighter and it makes burn outs really "fun".
Old Aug 10, 2004 | 08:36 AM
Studly_1's Avatar
Default check it out
<ul><li><a href="http://www.tirelast.com/id15.html">nitrogen FAQ</a></li></ul>
Old Aug 10, 2004 | 09:09 AM
Default Nice article, no sceintific data, but nice.....
I am not sure I believe the Nitrogen diffusing slower than air. But what do I know.
The rolling resistance is a function of tire pressure, not the composition of the air in the tires. I check my pressures about every other week. (Or 4 times a day if I am at the track.) I visually check my tire every day. I wear thru the tread way before my sidewalls deteriorate due to oxidation. The rim integrity has some merit, but if you are not running steel wheels (Aluminum alloy wheels) it is minimal. Aluminum oxidizes almost instantly; the advantage is that this oxidation then "seals" the metal preventing further oxidation. Almost the opposite of carbon steel.
Again, in my opinion...The reward (if even noticeable to a normal driver) is not worth the effort. If you want to be really lazy and never check your tire pressures, then sure N2 will help. But save the $20 and check your tire often.
Exception.... it is for a "weekend" car that sees very few miles, infrequent driving, and no winters (long storage). Then it might be worth it. My summer tires last 2 seasons max. My winter's get maybe 3. They are replaced before deterioration is an issue.
Old Aug 10, 2004 | 10:25 AM
skabaru's Avatar
Default the major benefit is it doesn't change pressure over temps as often...
so setting it at 41psi cold will remain near 41psi hot... when compared to just normal air.
Old Aug 10, 2004 | 11:01 AM
mdwsta4â„¢uroslut's Avatar
Member
Default what if you put NAAAAAWWWWZZZZ in your tires?
that'd have to make your car faster, right?
 Michael S. Palmer
Old Aug 10, 2004 | 12:09 PM
raugusta's Avatar
New Member
More stable pressure and less noisy
Old Aug 10, 2004 | 12:22 PM
Wow. Your tires defy the laws of physics. So much for the ideal gas law.
