Tire pressure + rain + a track = (lower or higher)
Old Apr 20, 2005 | 10:41 AM
JustAdam's Avatar
Default Tire pressure + rain + a track = (lower or higher)
I am thinking lower as the rain would cool off the track and the tires, as well as connecting to the track with a better contact patch.
Dual benefit in a sense.
Now, I would like to know if I am right, am I?
Old Apr 20, 2005 | 10:46 AM
WindyCityS4's Avatar
IIRC, I added a pound or two.
Old Apr 20, 2005 | 11:11 AM
Shameless in Chicago's Avatar
Leave them alone. They won't heat up as much anyway.
Old Apr 20, 2005 | 11:29 AM
Luke@tirerack's Avatar
Former Vendor
can I just answer or do I need to prove it ????
Old Apr 20, 2005 | 11:49 AM
I was hoping you would respond and I will take your word for it.
Old Apr 20, 2005 | 12:52 PM
Former Vendor
Default Re: Tire pressure + rain + a track = (lower or higher)
<center><img src="https://www.tirerack.com/images/tires/tiretech/hydro_edge/hydro_edge_main_sm.jpg"></center><p>tire properly inflated to 35 psi sitting still in the water on the glass plate. This provides an accurate idea of the tire's footprint size and shape.
Old Apr 20, 2005 | 12:53 PM
Former Vendor
<center><img src="https://www.tirerack.com/images/tires/tiretech/hydro_edge/hydro_edge_60_35_sm.jpg"></center><p>a tire properly inflated to 35 psi, driving across the glass at 60 miles per hour. If the glass plate were dry, the footprint size would be virtually identical to the first picture because air does not prevent the tread from contacting the plate. However with standing water on the plate, the tire's tread depth and tread design must evacuate the water as the tire rolls across the plate at 88 feet per second. You will notice that the footprint still shows good contact with the plate, but is slightly smaller than the static tire's footprint.
Old Apr 20, 2005 | 12:57 PM
Former Vendor
<center><img src="https://www.tirerack.com/images/tires/tiretech/hydro_edge/hydro_edge_60_30_sm.jpg"></center><p>a tire inflated to only 30 psi, again driving across the glass at 60 miles per hour. With the same amount of standing water on the plate, the center of the tire's tread is lifted as the tread design unsuccessfully attempts to evacuate water as the tire rolls across the plate. You will notice that the actual footprint shows poor contact with the plate and is significantly smaller than the footprint in the photograph of the properly inflated tire.
 Michael S. Palmer
Old Apr 20, 2005 | 12:58 PM
Former Vendor
<center><img src="https://www.tirerack.com/images/tires/tiretech/hydro_edge/hydro_edge_60_25_sm.jpg"></center><p>a tire inflated to only 25 psi, driving across the glass plate at 60 miles per hour. With the same amount of standing water, the water lifts the center of the tire's tread as its footprint rolls across the plate. You will notice that the actual footprint shows little contact with the plate and has been virtually reduced to the shoulder areas.
Old Apr 20, 2005 | 12:59 PM
Former Vendor
Default so, with all that said ..... you need to run higher pressures in the rain
and you will see better performance and grip .... also as previously mentioned the tires will run slightly cooler so, you will not see as much pressure increase
