Coilover Ride Height Question...
" Conservative Street Setup
Between 1/16 and 1/32 TOE IN front and 1/32 TOE IN rear
Ride height at 25.875” front and 26.000” rear
(�"1.0 camber front)
Aggressive Street Setup
Between 1/32 and 0 TOE IN on all four corners
Ride height at 25.500” front and 25.625” rear
(�"1.5 to �"1.75 camber front)
Track Setup
Between 0 and 1/16 TOE OUT on all four corners
Ride height at 25.000” front and 25.250” rear
(�"2.0 to �"3.0 camber front) "
It seems that I can go much lower than 25", is there any benifit to this? Should I dial it in to the aggressive street set up, get an alignment, then crank it down for auto-x/track days? Should I drop it as much as possible and then get the alignment...it seems that the aggressive street set up is too high...
any input?
<img src="http://pictureposter.audiworld.com/29399/100_0032_sig.jpg">
is that correct?
