I really do work for a living.....But you guys will just call it a caption contest
Old Jun 15, 2005 | 07:00 AM
PaulW's Avatar
Default I really do work for a living.....But you guys will just call it a caption contest
From my recent seminar that we give twice a year to personnel who work at nuclear plants. This is a motor repair shop I represent in New Haven, CT.
Me being the stud I am:
<img src="http://www.aesnuclear.com/images/seminar1.JPG">
<img src="http://www.aesnuclear.com/images/seminar2.JPG">
<img src="http://www.aesnuclear.com/images/seminar3.JPG">
<img src="http://www.aesnuclear.com/images/seminar4.JPG">
Flame spraying a shaft to restore a bearing fit. It is then machined to final size.
<img src="http://www.aesnuclear.com/images/seminar5.JPG">
<img src="http://www.aesnuclear.com/images/seminar6.JPG">
Making a random wound coil for a submersible pump motor and winding it.
<img src="http://www.aesnuclear.com/images/seminar7.JPG">
<img src="http://www.aesnuclear.com/images/seminar8.JPG">
A two speed, 400 HP/1000 HP vertical circulating water pump motor, it's so big because it runs at only 225/400 RPM. It's the big green thing in the back.
<img src="http://www.aesnuclear.com/images/seminar9.JPG">
A 3 HP vertical diesel generator fuel oil transfer pump motor. It came in on emergency, it's nuclear safety related and we got $21,000 to do a rewind of it, takes about 4 days.
<img src="http://www.aesnuclear.com/images/seminar10.JPG">
A 250 HP pump motor that failed. You can see that two of the phases open circuited and it ran on a single phase for a while before it tripped, that's the white windings that you can see, it was running on that single phase.
<img src="http://www.aesnuclear.com/images/seminar11.JPG">
Here's that submersible pump rotor on the balance machine. It has the impeller attached to it. Notice the fan cooling blades on each end of the rotor, that's what they are suppose to look like.
<img src="http://www.aesnuclear.com/images/seminar14.JPG">
Here's a rotor from a 125 HP motor that got loose on the shaft (the shaft is removed in these pictures), it then slide down the shaft and the rotor came in contact with the endbells of the motor.....ouch!
<img src="http://www.aesnuclear.com/images/seminar12.JPG">
<img src="http://www.aesnuclear.com/images/seminar13.JPG">
Old Jun 15, 2005 | 07:19 AM
carbonLORD's Avatar
AudiWorld Uber User
Neat stuff Paul, really!
Old Jun 15, 2005 | 07:34 AM
AdamS4's Avatar
do you have an engineering background? (maybe i'm captain obvious) neat stuff
Old Jun 15, 2005 | 07:50 AM
PaulW's Avatar
Default Was in the nuclear Navy after I dropped out of college
That's where I got my edumacation.....operated nuclear power plants on submarines.....I was enlisted.
Have been in the commercial nuclear power industry for the last 15 years since I got out of the Navy.
Old Jun 15, 2005 | 07:57 AM
AdamS4's Avatar
wow, very cool
tonypai's Avatar
Junior Member
Default And look what else you can do with this!
Plagarism is the first rule of scholarship.
<img src="http://www.vr6jetta.com/tree4.jpg">
<img src="http://www.vr6jetta.com/tree2.jpg">
Old Jun 15, 2005 | 08:02 AM
PaulW's Avatar
Default Post that on the A8 forum.....would look better coming from you!
Very funny!
Old Jun 15, 2005 | 08:11 AM
shrtbus(w/ cq)'s Avatar
Default .
Check out my sweet dance moves!
 Michael S. Palmer
Old Jun 15, 2005 | 08:50 AM
520's Avatar
520
Pretty cool
Old Jun 15, 2005 | 09:04 AM
gription's Avatar
caption - " Paul will now demonstrate how to lube his shaft"
