xpost from b6 forum... need some advice for troubleshooting a xenon light...
Old Jul 1, 2005 | 09:04 AM
siberian's Avatar
Default xpost from b6 forum... need some advice for troubleshooting a xenon light...
I have an older set of OEM xenons (from an A6)that I retrofitted to my old 98 A4 a few years ago, and I am planning on transferring them now to my new 03 A4. However before I do this, I need to try and solve a problem I have been having with them lately.
Every once in awhile when I go to turn them on, sometimes one side or the other won't light up. Usually it happens with the passenger side, but sometimes the driver side does it as well.
What happens is when I turn on the light switch, the bulb will flash, as if it is trying to ignite, but then it won't stay lit. If I flick the switch on and off a few times, eventually it will stay lit. This is a random, intermittant occurance.
Has anyone seen this before? I am wondering if it is a sign of the bulb starting to go bad, or a more sinister problem, like maybe the ignitor/ballast is going bad. I think I can rule out the switch because if the switch was bad, then the bulb would never even flash at all.
Any suggestions? When a bulb starts to go bad, does it act like this, or would it simply stop working all together?
Old Jul 1, 2005 | 09:25 AM
PaulW's Avatar
I had same problem, the bulb needs replacement in my case
Old Jul 1, 2005 | 09:35 AM
TonyPNS's Avatar
Swap the bulbs and see if the problem transfers
Old Jul 1, 2005 | 10:07 AM
siberian's Avatar
Default Are you talking about the connector that plugs directly into the bulb itself?
cuz that ain't aftermarket... it's OEM Audi, harvested from a wrecked car years ago.
Klickflip
A4 (B7 Platform) Discussion
Mar 23, 2017 02:48 PM
B6 3.0 Quattro USP
Oct 6, 2008 08:17 AM
Absltgreek (Mafia)
Jun 16, 2003 09:44 AM
Corey
Nov 13, 2002 05:32 PM
