Dynoed the Mini for kicks today...pretty much what I expected.
Old Oct 5, 2005 | 01:40 PM
markbradford's Avatar
Rest In Peace
Default Dynoed the Mini for kicks today...pretty much what I expected.
<center><img src="http://homepage.mac.com/raudi77/.Pictures/Mini%20Pics/MiniDynoPull.jpg"></center><p>177whp
169wtq
Mods: Alta 15% pulley, Milltek exhaust, Alta intake, and Alta intercooler. Total outlay approx $1500.
Generally Mini owners use 12% as their driveline loss number, so it's about 201hp at the crank. Now bad, considering per Al, his Dyno Dynamics dyno reads lower than any other type of dyno out there.
Old Oct 5, 2005 | 01:48 PM
Nvr2Fst's Avatar
Senior Member
thats respectible for the car...arent you happy?
Old Oct 5, 2005 | 03:06 PM
PaulW's Avatar
Damn that runs rich at boost!
Old Oct 5, 2005 | 05:31 PM
KiltedA4's Avatar
your videos never work for me....is it a mac thing?
Old Oct 5, 2005 | 07:02 PM
skabaru's Avatar
iMovie?
Old Oct 6, 2005 | 04:40 AM
PaulW's Avatar
Default Where are you reading that?
<img src="http://homepage.mac.com/raudi77/.Pictures/Mini%20Pics/MiniDynoPullAF&Boost.jpg">
Actually, now I'm confused. I see when boost is 24 PSI, AF is about 9:1. When it's 19 PSI (at the 5500 RPM intersect) AF is about 10:1.
It never gets above 10.8:1 or so anywhere on the chart....but I don't get the relationship between boost/RPM/AF.....do you draw a vertical line from the RPM scale?
Is it because where boost is being measured (is it downstream of the throttle plate?) that it goes down with an increase in RPM????
Old Oct 6, 2005 | 05:41 AM
thefaint's Avatar
New Member
What do you expect for a 0-60 time with those numbers?
Old Oct 6, 2005 | 05:44 AM
TonyPNS's Avatar
24psi?? The lower line is boost, not the upper.
 Michael S. Palmer
Old Oct 6, 2005 | 05:49 AM
RockaTTansky's Avatar
New Member
Where did you dyno, and can they do AWD?
Old Oct 6, 2005 | 06:02 AM
520's Avatar
520
And the upper is AF....but I don't think Mark you ar running too lean on low rpm's
